Bizhub "e" series issues
  • SmellsHot
    Head Tech
    • 512
    Just want to see if anyone else is having issues with these machines. Every other "e" series machine I get has issues within the first week. So far I've had bad MEMS, HDD's, MFPB's, and PRCB's, as well as a handful of having to perform all data clears to fix the machine. And boy does it suck installing and fixing a machine in the same week. Not a good image for my company or Konica. Is anyone else seeing these problems?
    Everyone has the right to be stupid. Some people just abuse this privelage more than others
  • jotunn
    • 618
    Re: Bizhub "e" series issues
    Bizhub C224e - dead SSD after around 260 copies, machine hangs during early stage of bootup process (2 grey elements of total 5 on bootscreen) - just can't load part of firmware from SSD. It's 95% BGA soldering failure because of shitty RoHS directive, as with earlier (C224 series) PWB-MFP boards.
    • tsewk
      • Jun 2013
      • 5
      From my experience, it is better to perform clear all data and format HDD for all e series new machine
      And the HDD is not as good as before, therefore you can try physically unmount HDD and start the MFP to check whether the HDD has problem
