please help for administrator password (Konica Minolta Bizhub Pro C5500)
  • technosystems
    • 34
    [Misc] please help for administrator password (Konica Minolta Bizhub Pro C5500)
    My machine Konica Minolta Bizhub Pro C5500, I purchased it used ..
    after installing the fiery i can't enter as administrator or operator, just enter as guest because i don't have password for administrator or operator
    may be any standard password used for administrator on this machine, or any way to can using the fiery as administrator .... please help
    Ahmed Aboelelaa
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: please help for administrator password (Konica Minolta Bizhub Pro C5500)
    Ahmed Aboelelaa
    You have tried the generic password - Fiery.1, right?
    • technosystems
      • 34
      No brother I did not know any password to try
      I'll try, is it : Fiery.1 ?
      Many thanks for your cooperation
      • technosystems
        • 34
        Dear,
        I tried to access the fiery as an administrator by using password : Fiery.1, but the Password not correct
        please help me if any thing can i do ..
        Ahmed
        • technosystems
          • 34
          Dear,
          Ahmed
          I want help my brothers
          I need to access my fiery
          any one help me please
          • ZOOTECH
            • 3375
            http://www.copytechnet.com/forums/co...eval-tool.html
            Have not tried this, but the reports were good - good luck.
            If you have problems, some of the replys may help.
            • Mick01
              • Nov 2012
              • 362
              If the retrievel tool does not work, the only option is to reload the system software on the Fiery. This will reset the password to Fiery.1
              Have you tried no password? Sometimes password for Admin and operator is disabled.
              • technosystems
                • 34
                I tried, but to no avail
                My problem I can not see the desktop operating system on the Fiery, the controller works even Windows Xp logo appears, then the screen be grievance (does not show the desktop)
                any copy i do from another computer (workstation) only
                Therefore I hope that I can cancel the password without re-install the fiery application on the controller
                And now I can not understand how I can run this tool where I do not know what PostScrit file !!
                I gave this tool to my friend, who has canon machine and he tried to print it , but it make uninstall fiery from controller only, nothing else
                ii'm afraid to try to print it on my machine because if the fiery uninstalled, i can't reinstall it again due to the operating system wich on my controller and windows desktop not working
                please help me if any thing i can do
                Many thanks for your interesting dear
                Ahmed Aboelelaa
                • Mick01
                  • Nov 2012
                  • 362
                  Ahmed,
                  I have used this PS file before (a long time ago) to retrieve the admin password. Try the following steps
                  1: open command workstation and log into the fiery (guest is ok)
                  2: click on File-Import
                  3: navigate to where you have the password.ps file located
                  4: select "Direct" as the location (not "print" or "process and hold" or "print and hold")
                  The machine should print a page with the admin password printed.
                  I dont know whether the later system fierys will print the password. I believe system 9 and above will not.
                  The ONLY other alternative is to reload the system software. I know you want to avoid this but it is the ONLY way to reset the password to Fiery.1
                  you mentioned that you cannot see the operating system for the fiery (display goes blank after the windows xp load screen). This is normal for a Fiery. You have to have the "FACI" option installed for the server type fiery's (IC303/305). The embedded fiery (IC408) does not have this.
                  Good luck.
                  • Mr Spock
                    Vulcan Inventor of Death
                    • Aug 2006
                    • 2064
                    Ahmed,
                    Good luck.
                    It will print the password on almost all Fiery's. It may come out as a hash md5 printout (I think that is the correct one). Then google a hash to ascii translator, type it in and there is the password.
                    Usually you use the operational panel to access the fiery or via the network. Unless it has a faci kit and option monitor/keyboard/mouse.
                    • technosystems
                      • 34
                      Ahmed,
                      Good luck.
                      Thanks Dear, I'll try to do. but after taking a backup from hard disk as an ghost image. to exclude system re installing >> ok?
                      • mohammad fayaz
                        • Oct 2013
                        • 5
                        check this passwrd
                        12345678
                        or
                        00000000
                        • JustManuals
                          • Jan 2006
                          • 9838
                          This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
                          Paul@justmanuals.com
                          • technosystems
                            • 34
                            Dear, i bought my machine from France, so my fiery system by French language
                            Fiery option on machine monitor by French
                            Printing options on any computer on network by French
                            Did you know any way to can replacing it with English ??
                            thanks,
                            • ZOOTECH
                              • 3375
                              thanks,
                              Reload system software, it will prompt you for the language.
