Bizhub pro 920 error code 46-25
  • stabouloglou
    [Error Code] Bizhub pro 920 error code 46-25
    I HAVE PROBLEM WITH THE 920, throws me CODE 46-25. I HAVE ALAXEI KALODIOSI, lamps, PCB feeder. THERE IS SOMEONE WHO CAN GIVE SOLUTION;
  • Luther
    • May 2006
    • 682
    Re: Bizhub pro 920 error code 46-25
    Check if you have your optic mirrors clean, as well as the lamp and the CCD lens. That was my problem in both my machines (the CCD couldn't read the white stripe at powerup).
    Other possible causes:
    - Optics motor
    - Bind on any paper tray lift (try the machine with the trays open and close them one at a time if the error disappears)
    - Look for a piched wire oin the registration unit.
    - also i think there is a fuse on the lamp section if i remember correctly
