I got this 601 in a few days ago and was baffled that the thing would not keep my manual IP address settings (except sub and gateway) and DHCP wouldn't work either.
I wanted to reset the NIC, but there does not appear to be NVRAM recovery special firmware for the 601/701 (despite being clearly listed in the NVRAM recovery documentation)
I ended up getting it to work, but I instead of "Print Controller", on my machine its "Network" (see the Solution ID) and had to set it to "set."
Restart, Enable Network in Admin mode, Restart, Add Addresses.
I replicated this three times to verify I am not crazy.
This is backwards right--shouldn't "setting" the Network in Trouble Isolation disable it?
Also, the print drivers would not work unless I changed the TCPIP port settings to LPR 1.
The service manual states that the 601 is RAW compatible.
Printing Method lpd/lpr (TCP/IP), IPP (TCP/IP), AppleTalk (EtherTalk), PServer/RPrinter
(IPX/SPX), RAW Port (TCP/IP)
Solution ID TAUS0902240EN* Solution Usage 4
Description
The machine will not hold the ip address entered in the network setting of the machine.
Solution
PROBABLE CAUSES:
1. The print controller is in a trouble isolation state.
SOLUTION: Enter the service mode, select 'system one',then select'trouble isolation'. Set the print controller to 'unset' to release it from isolation. Once it has
been released, the ip address can now be entered and stored in the machine.
2. Problem with the network setting.
SOLUTION: Enter the adminstrator mode, select Network Settings, then select Network Setting and press the "Off" button. Turn off the main power. Then
turn on the main power, Enter the adminstrator mode, select Network Settings, then select Network Setting and press the "On" button. Turn the main power
off. At power on the IP address should "stick."
Description
Solution
PROBABLE CAUSES:
