Error Code c0070
  • ruth_oxley
    [Error Code] Error Code c0070
  • Hansoon
    • Sep 2007
    • 3385
    Re: Error Code c0070
    If the machine is throwing the C0070 code without the bottle being inserted than likely the worm gear of the little drive motor of the toner bottle holder is damaged.
    If C0070 is only coming up with the bottle inserted, than the bottle may be wrong or damaged from previous attempts.
    To reach the toner bottle holder ("hopper") mechanism you have to remove the rear cover.
    Hans
      • 14735
      Hans
      I don't think the Di251 has the worm gear drive. I think it is the same as the Di550 with the little three pointed "Pin". Check the pin to make sure it isn't cracked. Also clean the sensor at the back of the hopper. And make sure the locking mechanism at the bottom is working properly. If if isn't disengaging it will hold the bottle and not allow it to turn.
      Hope this helps
      • Hansoon
        • Sep 2007
        • 3385
        Inside the grey housing it has a worm gear. The similar, bot not identical with, motor of the di-450,550 looks identical from the outside but is different, hence the different part numbers.
        The Di-200, 251, 351 toner bottle holder drive motor do get damaged from time to time though not that easily as the old Di-350 with the open worm gear assembly.
        We never had on the Di-200, 251, 351 series the 3-winged coupler you mentioned go bad but it is a possibility ofcourse.
        Hans
        • WildbillC
          • Oct 2010
          • 49
          Hans is correct, it is most likely worm gear issue. That copier is no longer supported by Konica Minolta so you may have problems finding parts. Don't attempt it without a service manual (available from JUSTMANUALS.com).
          Bill
          • JustManuals
            • Jan 2006
            • 9838
            Ruth...........If you send an email to paul@justmanuals.com, I'll send you a free copy of the parts & service manual. Always happy to help out a non-profit.
            Paul@justmanuals.com
