Bizhub 250
  • George Jetson
    • Jul 2025
    Bizhub 250
    Has anyone come across a way to take paper trays out of the Auto tray select function other than setting the tray to recycle paper. When you set it to recycle paper if it is your fax reception tray it wont take it from that tray. Can you turn the auto tray switch off completley.
  • pepper38_cnd
    Field Service Manager
    • Aug 2005
    • 1075
    What is it you want to accomplish? No auto paper select? Or no auto tray switching? Or just set one tray for faxes only?
    Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
    Now into Ip TV KODI Boxes
    • pepper38_cnd
      • Aug 2005
      • 1075
      Maybe this attachment will help, from the KonicaMinolta SSD
      • George Jetson
        This copier has four trays. Tray 1 is normal, Tray 2 has green paper for faxes and is set normal, Tray3 has letterhead and is set to recycle paper thus taking it out of the auto tray select, Tray 4 is normal.
        My problem is if I set tray 2 to recycle paper to take it out of the auto tray select setting. The fax will not print from that tray.
        I know how to change fax priority tray but need a way to stop normal printing running on to green paper when the other trays run out.
        • pepper38_cnd
          • Aug 2005
          • 1075
          Have you tried setting the fax tray to LetterR and and setting the default tray in the print driver to the tray with regular Letter.
          • George Jetson
            The fax tray is the tray that the copier prints out the faxes it receives. If I change it from normal the fax prints out from another tray. In this case I only want faxes on green paper from tray2. I do not want anything from the computer to print out on green paper from tray2.
