bit switch to extend power save sleep modes C364e
  • rrrohan
    • Sep 2011
    • 1977
    Does anyone know the bit switch to extend the power save and sleep mode.
    Use to set it to 120mins but max now is 60mins.
    I know its not that big a deal but do recall a bit switch change that would extend the time and figure I may as well do it if its possible.
    PS I did search CSES but the search engine for that site is very particular and I havent had much luck finding it.
  • emujo
    • Jun 2009
    • 3009
    Re: bit switch to extend power save sleep modes C364e
    That 60 min max is part of ver 3 firmware. I don't think it can be overridden w/o downgrading to function version 2. Emujo
    • MRK23
      • Jan 2011
      • 19
      In tech rep mode you can go into systems 1 and select sleep mode and then select permit. Then in the admin mode under power setting you now have a yes/no option to disable sleep mode...note you can still only set the lower power mode to 60 mins...
