Konica Minolta bizhub pro c5500 / Error C-3508
  • technosystems
    • 34
    I have error no.: c-3508
    according to service manual it means :
    Fusing roller paper winding abnormality.
    J31-02 occurred four continuous times.
    help me dears, what can i do ??
  • RRodgers
    • Jun 2009
    • 1947
    Re: Konica Minolta bizhub pro c5500 / Error C-3508
    Well dear,
    Did you check the fuser?
    • Naren
      • Sep 2012
      • 10
      reset the error code through software SW then adjust the fusing exit roller
      • technosystems
        • 34
        please tell me the steps for to how to reset the error i don't now what's software SW
        • technosystems
          • 34
          My brother, here in my country i don't have any service from Konica minolta agent, so I need help to do my work and resolve my problems relaying on my self.
          When i start the machine, I receive the error immediately ( can't enter service mode )
          please help me if you know any code to can dealing with error in this case
          thanks for your interest
          Ahmed
          • Naren
            • Sep 2012
            • 10
            Ahmed
            Plz follow the steps
            The Service modeis inaccessible byentering Utility => Stop => 0 => Stop => 0 => 0 => 1. This is to prevent accidental reset of the code and
            causing additional damage to the machine. To reset a fuser abnormality code, perform the following:
            1. Power the machine OFF from the main switch leaving the sub switch ON.
            2. Press the utility Key and power ON the machine from the main switch.
            3. Enter Stop => 0 => 0 => Stop => 0 => 1.
            4. Press [03 System Setting] on the touchscreen.
            5.Press [01 Software SW setting] on the touchscreen.
            6.Press the left up-arrow, which is displayed on the touchscreen, 2 times. The number displayed above the up-arrow will change to 03.
            7. Select the bit number of switch 1, using the right up-arrow, 03-1 will be indicated.
            8. Press the [Return] key, which is displayed on the touchscreen.
            9. Exit Service mode to return to normal operation.
            • technosystems
              • 34
              Many thanks my dear,
              I did all steps but after finishing and Press the [Return], it return to the error again
              after i try again the numbers became as previous status : 01-0 !!!
              the changes not saved on machine
              what can i do ?
              thanks
              • technosystems
                • 34
                what can i do ?
                thanks
                • technosystems
                  • 34
                  Help Me please
                  • RRodgers
                    • Jun 2009
                    • 1947
                    Help Me please
                    So what did you find in the fuser area after you opened it up and had a look?
                    • technosystems
                      • 34
                      Nothing up-normal !!!
                      I tried again and problem solved, but i don't know how ??
                      Thanks brothers
                      Ahmed..
                      • Captain Jack
                        • Oct 2013
                        • 15
                        Pull fuser unit out and take a good look at the electrical plugs that would mate to the main frame when inserted, the may have a bent contactor and the ones on the main frame side may be pushed in or broken, If so you will need to replace connectors on both fuser assy. and frame side to do it right.
