minolta bizhub c350 error c-0990 & c-0996
  • cantonakis
    • 19
    Resently I got 2 minolta bizhub c350 after a page missfit from the LCD I am getting the c-0990 on the one with the fiery and the c-0996 of the the other. Does anyone know what is this and how to solve it please ?
  • Mark B
    • Jul 2006
    • 153
    Sounds like drawer codes. Reload the paper.
    • Accentcp
      Old Tech
      • May 2008
      • 14
      LCC paper shift I think.Straighten that stack and look behind drawer in cabinet!!!
      • ni311
        • May 2008
        • 658
        c-0990
        LCT Elevator Motor malfunction (Elevator malfunction)
        The Elevator Motor Pulse Sensor (PC10-LCT) cannot detect both edges of H/L
        even after the set period of time has elapsed while the Elevator Motor (M5-LCT) is
        turning backward/forward (raise/lower).
        Action
        1 Check the motor and sensor connectors for proper connection, and correct as necessary.
        2 Check the connector of motor for proper drive coupling, and correct as necessary.
        3 PC10-LCT I/O, sensor check
        4 M5-LCT operation check
        5 PWB-H LCT replacement
        6 PWB-C1 LCT replacement
        c-0996
        LCT Shift Motor malfunction
        The drawer cannot be determined to be out of position even after the set period of
        time has elapsed after the Tray Lock Solenoid (SL1-LCT) is energized after the
        lowering operation is finished.
        Action
        1 Check the SL1-LCT connector for proper connection, and correct as necessary.
        2 SL1-LCT operation check
        3 PWB-C1 LCT replacement
        I hope this help.
