'correctly position paper in bypass tray' error
  • swt
    • Jul 2010
    • 44
    We've got an issue printing compliment slips from the bypass tray on a couple of bizhubs (C360 and C280). The slips we use are a non-standard size, 210mm x 99mm, but we did get them to print ok last week. However, we now can't get them to print but I don't know what haschanged and, no matter what I try, I can't get past the 'correctly position paper in the bypass tray' error on the machine placing the slip with the short side feeding in. If I turn the paper around with the long side feeding it proceeds to print but doesn't get far 'jamming' at the right-side fuser unit.
    We last had it working using the settings below and I'd really appreciate any assistance to get it working again.
    Word Document
    Page Orientation: Landscape
    Print Driver
    Original Size (My Tab): A4
    Paper Size (My Tab): Custom (Width: 99.0mm Length: 210mm)
    Original Size (Basic Tab): A4
    Paper Size: (Basic Tab): Custom Size
    Zoom: Manual (100%)
    Paper Tray: Bypass Tray
    Paper Type: Plain Paper
    • 14791
    Re: 'correctly position paper in bypass tray' error
    Do you have the bypass tray set up as a custom size on the machine as well?
    • swt
      • Jul 2010
      • 44
      I did try this earlier today but the custom size was not available when I went to 'Paper Tray Setting' at the error screen. It is available now though - I just went to test again - and it prints fine when the custom entry is selected. This does require user input at the printer but I'm sure we can live with that.
      Many Thanks
