Bizhub 654 - Unicode
  • fancheta
    • Oct 2013
    • 30
    [Misc] Bizhub 654 - Unicode
    I had to reformat an HDD in a bizhub654 and now on the control panel, it is stating to install unicode fonts. I have the unicode fonts on a USB drive but no idea how to install them. I tried reflashing the fw as well but still prompts that message.
    Already looked thru service mode 2 > install data.
    This machine has licenses for unicode fonts and pdf/a fonts (already installed).
  • JustManuals
    • Jan 2006
    • 9838
    Re: Bizhub 654 - Unicode
    paul@justmanuals.com
    • dallas
      • Jun 2008
      • 115
      This is easy to handle.
      - Extract the OCR_Font_Data_USB.exe
      - Copy the 4 PDF-Files to the root directory of the USB-Stick
      - Connect the USB Memory on the right side of the control panel
      - Select the Button "Print a Document from external Memory"
      - The font Data in the USB Memory will be displayed, select these Files to print out
      - A error message will be displayed (Printing failed), but that's normal. Touck OK
      Print out a PCL Font List and confirm that the Font data (Anadale Mono WTJ, Andale Mono WTK, Andale Mono WTS, Andale Mono WTT) are registered.
      • fancheta
        • Oct 2013
        • 30
        thanks
