C-352 Jamming drawer 3 and 4
  • acsolutions
    • Jun 2010
    • 519
    [Jamming] C-352 Jamming drawer 3 and 4
    Hello, I have jam codes 1301 and 1401 from pedistal, I got called out for # 4 drawer. I thought possibly rollers or loop adjustment. Ran copies jammed after 10 and checked jam counters, showed only jams in 4 only, checked printer resist loop and and the values for drawer 3 and 4 were -6 and -4, I never set them like that. Pulled out the 4 assembly and checked clutches and cleaned rollers and sensors and set the resist loop to -5 and 0. I then ran 200 copies through 3 and 4 in test mode no problem then 200 copies no problem! I filled out paper work ready to go then ran another 10 and it started to jam through both drawers. I set the resist values back to original settings and it still jams. Help! Thanks
  • acsolutions
    • Jun 2010
    • 519
    Re: C-352 Jamming drawer 3 and 4
    Originally posted by acsolutions
    Hello, I have jam codes 1301 and 1401 from pedestal, I got called out for # 4 drawer. I thought possibly rollers or loop adjustment. Ran copies jammed after 10 and checked jam counters, showed only jams in 4 only, checked printer resist loop and and the values for drawer 3 and 4 were -6 and -4, I never set them like that. Pulled out the 4 assembly and checked clutches and cleaned rollers and sensors and set the resist loop to -5 and 0. I then ran 200 copies through 3 and 4 in test mode no problem then 200 copies no problem! I filled out paper work ready to go then ran another 10 and it started to jam through both drawers. I set the resist values back to original settings and it still jams. Help! Thanks
    could it be that both feed assemblies are bad!
    • JustManuals
      • Jan 2006
      • 9919
      Paul@justmanuals.com
      • acsolutions
        • Jun 2010
        • 519
        I have a manual, but thanks anyways!
