I have a C550 with very low mileage (15k, Show room). I have a jam indicator at screen at paper exit (In service mode it shows as "1"). Replaced Paper exit sensor at the right side door but jam is still there. Please help me to find out what I am missing.
C550 Jam indicator at Paper Exit
Re: C550 Jam indicator at Paper Exit
Paul@justmanuals.com
Try cleaning/replacing the one way clutch at the turnover/exit sectionComment
Hello,
do you have upgraded the firmware?
There normally is a black cover on the sensor, is this cover still there?
Greetings
MarcoComment
make sure that the exit sensor actuator is working correctly, it can stick in the operated position or not swing back far enough if the sensor mount is bent!Please do not PM me without asking first.Comment
I push the sensor while kept the side door open and then swing the flag that goes in sensor but it did not change. It is swinging freely. Home position as I see. Flag stays between Sensor.Comment
Did you also changed the photo interrupter?
The same interrupters are in the LCT's.
You can take them for testing.
greets MarcoComment
