Bizhub 421 jamming out of tray 1 only
  • BSGINC
    • Jan 2012
    • 19
    [Jamming] Bizhub 421 jamming out of tray 1 only
    BH 421 558K We have a problem child machine , we have replaced the feed roller, clutches, drive clutch registration assembly and still have jamming out of tray 1 only. Swapped tray one with tray 2 and still jamming out of tray1, trays 2,3,4 run fine.
    Running out of thoughts. Suggestions?
  • xscotty1990
    • Nov 2013
    • 40
    Re: Bizhub 421 jamming out of tray 1 only
    Dumb answer:
    Maybe wrong paper? Had the same mistake on a bizhub 250. All other trays were working fine except tray 1.
    We changed everything also the door. Finally it was bad paper.
    When its feed from tray 2 - 3 there are black rollers which help to transport the paper to the drum. Tray 1 has no black rollersover the feeding rollers i think.
    Greets
    Marco
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • BSGINC
        • Jan 2012
        • 19
        Originally posted by xscotty1990
        Dumb answer:
        Greets
        Marco
        Paper is the same a s tray 3 and 4
        • fixthecopier
          ALIEN OVERLORD
          • 4713
          When you say clutches, does that include the 1 way bearings next to the feed and sep rollers? Will it feed at all? Does it stop while pulling paper, or leave it in the tray?
          • BSGINC
            • Jan 2012
            • 19
            We changed the mag clutches and tray 1 feed section out, the paper feeds to the transport guide and stops.
            • fixthecopier
              ALIEN OVERLORD
              • 4713
              Did you remove the gear pack that sits behind tray 1 and change that clutch. The one you have to remove the by pass and both tray feeds to get to? That gear pack has about 2mm of slip in the screw holes, and must be pushed all the way up to work.
              • BSGINC
                • Jan 2012
                • 19
                I will check with one of our other techs he had taken that out .
                Thanks!
                • CraigW
                  • Dec 2010
                  • 417
                  What are the jam code #s that appear on management list ??
                  • GTgosu
                    • Mar 2013
                    • 19
                    check one more time e-rings and c-rings,whether are on right place
                    • brent
                      • Nov 2008
                      • 1212
                      when you say you replaced all those clutches. did you take the back pannel off. unplug unscrew and remove the first tray clutch? ask your tech that. there is a clutch in an assembly that gets overlooked because it is a pain to remove. along with that. the shaft needs replaces with that kind of a meter. let us know
                      brent
