cyan color problems on a bizhub C550
  • niticom
    • Dec 2011
    • 12
    the problem I have is with a C550 bizhub, the cyan color has quality imaging unit is 70% of your life useful however strong blue does not come into place only goes magenta (I leave some pictures to printing can see the test) on the screen too leave me the P6 and P21 indicators. agradesco their opinions.
    Compare the images that sending good and the other with the problema.escanear0001.jpg
  • Synaux
    • Mar 2012
    • 1224
    Re: cyan color problems on a bizhub C550
    Compare the images that sending good and the other with the problema.[ATTACH=CONFIG]23135[/ATTACH]
    Just because the IU is not near EOL does not mean it is not defective, have you tested the cyan IU itself?
    P-6 is cyan IU failure.
    P21:Transfer belt unit/PH unit/Printer control board (PRCB)
    Step Action
    1 Wipe clean the surface of the transfer belt with a soft cloth, if it is dirty.
    2 Change the image transfer belt unit if the transfer belt is damaged.
    3 Change the PH unit.
    4 Change PRCB.
    (5 while you are there clean the IDC sensors too).
    • RRodgers
      • Jun 2009
      • 1947
      Start off with a reset and stabilize, then go into tech mode and print out a cyan gradiant page. Then print out a any one of the other colors, if they don't match I'd be looking into a new IU. Has this IU been chipped? After a while sometimes the chipped IU's will lose Dev and you won't get decent solids.
      Report back.
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • Ubtessy
          • May 2015
          • 4
          Hello, call a technician to top or add Developer to that Unit and it will be ok, its cause by shortage of DEVELOPER
            • 14817
            It is a two year old thread. I would hope he either has it fixed or replaced by now. lol
            • Synaux
              • Mar 2012
              • 1224
              This is the second "developer epiphany" I have noticed--on posts that I have responded to over a year ago.
              Got to love it.
