bizhub 224 / 445 mac settings
  • dickierock
    • 252
    Hi,
    Can anyone with more Mac experience guide me with driver or machine settings for getting the best quality from pdf prints.
    The customer had a ricoh previously and finds the new 454 a bit flat on the colour quality.I have used "print as image" and various settings to improve a bit but if anyone with Mac expertise let me know how they set them up I would very much appreciate it.
    Cheers all.
  • occus
    • 339
    Re: bizhub 224 / 445 mac settings
    Hi
    That's not so easy, because ricoh has a original postscript driver and KM use a emulation... there is a big difference.
    I get the best quality with a self created icc profile... no chance to get a good solution without your own profile! buy a colormeter from xrite or something like that.
    there are different decisions... always follow a line not cross over!
    Level 1, in Software:
    If your customer use adobe software, (color-management by software or by printer) use printer for solid prints but the colors are not really true. It's also a question of cmyk or RGB, use by Software only if you have your own created icc, and copy it in library>colorsync>profiles, after you can choose in dropdown menu.
    Level 2, in OSX:
    Driver Adjusments but Mac based, >Colorsync: by ICC or by Printer (use printer or icc if you have your own and your software have not a own color-management choice)
    Level 3 in Printer Driver:
    in the quality tab (i don't know the english driver mask but hope you understand)
    1. pure black > on
    2. raster > gradation
    3. color typ >metric (the last one in the list) and make the sam adjustments for 3 areas, texts photos and graphics
    ... i loose many many many hours by testing the different adjustments and have now a lot of experience with the machines... and had never found somebody who can explain me the best adjustments... because you have to know the mac/the adobe software/the bizhub machines all together and not only a part, thats difficult.
    • dickierock
      • 252
      Occus,thanks very much for your input,
      I will look at these and just one other thing.
      I notice the mac's are very slow to spool the print job?It seems to take a long time on the print queue.
      Is this an issue with the konica minolta mac drivers?
      Is there anything can be done to improve this?
      Many thanks Occus.
      • occus
        • 339
        slow printing? compared to what? to the rico or to PC Windows?
        Windows use printerlanguage PCL and Mac use Postscript. And 1 sentence code in pcl is a hole page code in PS, of corse the PS is slower than PC Windows.
        The rico use original PS, which can speed up, i don't know...
        -update your network to 1000mbit.
        -try to install the printer with a other protocol, bonjour or not IP... if you get a error (IPP V2 not supported) take the IP protocol.
