Bizhub 163
  • zaza
    MECANOGRAPHE
    • Mar 2008
    • 1095
    [Error Code] Bizhub 163
    well bizhub 163 if l started there this machine this error code appeared there C05000....and this machine Extinguished alone....l trying controlled the fusion parts but all is good ...please help
    BEST TECHNICIAN . NICE PEOPLE .
  • JustManuals
    • Jan 2006
    • 9838
    Re: Bizhub 163
    http://www.justmanuals.com
    Paul@justmanuals.com
    • Hansoon
      • Sep 2007
      • 3389
      Re: Bizhub 163
      There is no C05000 in this machine. However C0500 means warm-up failure of fuser unit. Reset by holding the Stop Key down at the same time switch the Power Switch on.
      Hans
      • tonerspot
        • Nov 2008
        • 79
        Re: Bizhub 163
        Check the switch for the right door, it is not actuated, on the rear of mashine
        • zaza
          MECANOGRAPHE
          • Mar 2008
          • 1095
          Re: Bizhub 163
          well excuse me ...l wrong ..the error code is C0500 ...l know it have warm-up failure ..l trying controlled the fusion section parts ...but it is very good ....please it have any idea to raster this error code how can enter in mode save ??
          • Hansoon
            • Sep 2007
            • 3389
            Re: Bizhub 163
            .....and see what happens if it returns.
            Hans
            • RWAFA
              • Aug 2011
              • 68
              Re: Bizhub 163
              You can reset this problem by pressing the following buttons:utility key-stop 00 stop 01 then trouble reset,then do the reset.
              • zaza
                MECANOGRAPHE
                • Mar 2008
                • 1095
                Re: Bizhub 163
                hello all ..l informed you l solved my problems ....l taken my finger fix to stop long 5 second l started switch of copiers any all is very good ...thanks very good to all technician help me ...
                • Hansoon
                  • Sep 2007
                  • 3389
                  Re: Bizhub 163
                  Just curious to know: Is this a direct translation from Arabic or French through Google Translate or does Zaza have a minor Frimwar problem......
                  Hans
                  • zaza
                    MECANOGRAPHE
                    • Mar 2008
                    • 1095
                    Re: Bizhub 163
                    [QUOTE=Hansoon;392666]Just curious to know: Is this a direct translation from Arabic or French through Google Translate or does Zaza have a minor Frimwar problem......
                    Hans[/QUOT
                    what's happend friend hans ...
