C-FA14 - Thread Software Error - Related parts: Whole machine
  • Phrag
    • Oct 2012
    • 417
    Hi everyone.
    Bizhub 652 issue. After the completion of every print job, the machine hangs (with the job still in queue saying "printing"), then I get a screen stating to "Please turn main switch off and on."
    I've firmwared this machine (It's currently GCH-F9). MFPB has been replaced very early on in its life for a different issue, HDD cables reseated. Issue still there.
    I'm going to test printing from my laptop to eliminate their network. I'll let you know how I go.
    Anyone else had this issue?
  • dirtyfingers
    • Sep 2013
    • 35
    Re: C-FA14 - Thread Software Error - Related parts: Whole machine
    This is one of the BW models
    We had one here but fixed by doing firmware.
    Check the marketing area is correct for your region
    <Symptom>
    "Please turn main switch off and on."(FA14) may be displayed if the following procedure is operated.
    <Reproduction Procedure >
    - 8K or 16K and other document size.
    • EarthKmTech
      Step aside, noob
      • May 2009
      • 2139
      Gotta love the service manual description of this fault code, basically its saying to the tech "F-ked if we know, work it out for yourself!"
      If it were me i would suspect either the HDD or the MFP board, but i would also be checking and ensuring the customer is using the correct driver. Its not uncommon for IT "professionals" to not understand the difference between a C and a non C machine when installing drivers.
      • Phrag
        • Oct 2012
        • 417
        Cheers guys. I'll check out all those suggestions. I'm going to pull out a 2nd hand HDD from a machine here at work as well, just in case.
        It's had 2 C-D00F codes yesterday too.
        I
        shouldn't have asked how their machine was going...
        • wseyller
          • Sep 2012
          • 1129
          I also say MfP board or even HDD. I've add this error on newer model where Mfp board has fixed the issue. See if there is some memory or HDD test in service mode and have it run through them.
          Sent from my DROID BIONIC using Tapatalk
          • Phrag
            • Oct 2012
            • 417
            MFP board will be the last thing we replace after every avenue has been check twice I think. It was only replaced not long after the machine was first installed.
            What I ended up doing in the end, was replacing the HDD with a 2nd hand one. Formatted that, and away we go. Time will tell I guess.
            They were using the correct driver. Marketing area was fine. I also eliminated their network, and tried printing directly from my laptop, which worked fine. I got them to retest printing after this new HDD was put in, and everything seems fine.
            The last thing I'll try is get the IT guys at the Education department to change IP address, and perhaps reinstall the driver. It's on a school server, so I can't touch anything.
            So they'll let me know if anything happens. Cheers guys. Hopefully it's sorted. Holidays Next week. YAHOO!!
            On a unrelated note, has anyone had a machine freeze on power up (at the KM screen)? I'm sure you have. I replaced MFP boards, RAM and all sorts, only to find out it was a faulty port on the switch.
            • Phrag
              • Oct 2012
              • 417
              TYep. Ran those tests. Everything seemed fine. But I swapped HDD's anyway.
              • Synaux
                • Mar 2012
                • 1224
                My experience dictates: beware of the IT people/things.
                Glad you got it working (hopefully), Phrag!
                • EarthKmTech
                  Step aside, noob
                  • May 2009
                  • 2139
                  I've had this before on 2 x c280's at a single school after lightning blasted the crap out of their switches.
                  Machines would boot but lock-up at the ready screen and only come back to life when and while the network cable was unplugged. Plugging directly into a laptop was fine. My guess was that the switch was sending its power supply voltage straight down the network cables.
                  After the switches were replaced the copiers were fine.
                  • Phrag
                    • Oct 2012
                    • 417
                    Yeah. I couldn't understand what was doing it. It was 2 hours out of town, so prior to going out there, I was liaising with one of the Councils IT blokes. He said he changed network cables, but it turned out it was only that 1 single port on a switch of 30 or something ports.
                    On top of that, it was in a donga (i don't know what you guys call it) in the middle of nowhere. Highly skeptical that it was running off the grid. More like Generator or something.
                    • SAR
                      • Jul 2009
                      • 203
                      Thanks for posting this! I just had a Bizhub 552 (black & white) that had the "turn the main switch off and on" message w/the FA 14 code. The machine was dead and every time you turned the main switch off and on, it just came up with the message again. Replacing the Hard Drive fixed it. Tried the special firmware first, but it didn't fix the problem.
                      • EarthKmTech
                        Step aside, noob
                        • May 2009
                        • 2139
                        Also experiencing this on a 652 black.
                        Hdd was replaced earlier on in its life, but noticed another singular hdd error a few weeks ago in the error code log among nothing but FA14.
                        Ongoing issue with mine every day & customer getting annoyed, so have changed HDD again, new MFP board, new Ram, initialized NVram and completely reconfigured machine from scratch. It is running the latest FW and always has been. If this is still going on then F'ed if i know, I'm out of ideas.
                        • Specialist
                          • Jun 2014
                          • 21
                          There is special firmware available for this problem....GCZ-D1
                          • Mackieman1967
                            Anyone ever figured this out? We tried all of the abovery tips!!!
                            • mx6turbo89
                              • Oct 2013
                              • 154
                              Try special firmware GDH-D1.
