Bizhub 163 is not printing
  • spree
    • Jun 2012
    • 211
    I have a problem with Konica Minolta Bizhub 163.
    The machine is like a new with very few copies, but have a serious issue.
    I firstly configure the IP address, but have no ping.
    Then I plug it to USB and tried to install through installer.
    Installation completed correctly.
    I tried to print a test page, but nothing happened, it was still in queue.
    On display there was no information, it was ready.
    Copying is working.
    I tried it install on Win XP PC and Win 7 32-bit PC.
    Please, have you any ideas or suggestions what can cause it and where can be a problem?
    Thanks.
  • Hansoon
    • Sep 2007
    • 3391
    Re: Bizhub 163 is not printing
    What's the history of the machine? Is it a lease return or something? Could be that somebody messed up with the additional IC-206 controller and/or NIC interface NC-503.
    This machine comes standard with a GDI interface with USB only. To install the above mentioned controller and NIC it needs special setup.
    Hans
    • spree
      • Jun 2012
      • 211
      It's probably lease return.
      It have only 3000 copies overall and look very good.
      I've installed always PCI drivers.
      Which special setup is needed?
      Can you describe it?
      I have all service manuals for it.
