I bought new Konica Minolta C353, I used to get prints are fine, but when I make photocopy in my new machine, it come with Black BLOCK, how can I cancel the option, Image is attached in this, please get back to me
Copier Problem in New Machine
Re: Copier Problem in New Machine
Paul@justmanuals.com
There are 75 references to the installation in this manual.Comment
Mr. Spock is correct, you missed something in setup. Had a similar problem way back after I failed to set the time in the machine during setup.Comment
1st, I don't believe you got a "new" C353, maybe new to you though. The blocks you are getting are probably from a failed System Control Board. Performing the original setup incorrectly produces the "lines of shame", not blocks. If you think you bought a "new" MFP and want to double check, I'm sure we can give you some things to look at to be sure you weren't suckered. EmujoIf you don't see your question answered in the forum, please don't think it's OK to PM me for a personal reply...I do not give out firmware and/or manuals.Comment
You need to not cycle power and adjust these (then power cycle)
Date and time (I believe in administrator mode)
Location
Adjust Touch panel
Install Date
List Output (I don't do this)
and maybe one or two more other things...I cannot seem to find my notes--how annoying...
In my experience, you do not need to perform any of the ADF adjustments and gradation adjustments to rid yourself of these security blocks.
If you get the installation manual from JustManuals and still cannot get it to work it out let me/us know.
"The blocks you are getting are probably from a failed System Control Board. Performing the original setup incorrectly produces the "lines of shame", not blocks."
Emuju, lets hope its not a failing board, but I have seen these blocks after NVRAM flashing (older models)...effectively requiring the installation process to be administered.Comment
1st, I don't believe you got a "new" C353, maybe new to you though. The blocks you are getting are probably from a failed System Control Board. Performing the original setup incorrectly produces the "lines of shame", not blocks. If you think you bought a "new" MFP and want to double check, I'm sure we can give you some things to look at to be sure you weren't suckered. EmujoComment
I finally found what I was looking for
Do these in this order:
Touch Panel Adjustment in Accessibility settings
Gradation Adjustment in Service Mode
Date/Time setting in Service Mode
Date/Time setting in Administrator Mode
Enter Install Date in Service Mode
Serial Number Input in Service Mode
List Output in Service ModeComment
