Konica 7155 (J32-10)
  • Maindron1
    • Mar 2011
    • 38
    I wonder if any of you had ever had a j32-10 jam at start-up, I tried a different fusing unit and I still get the same thing. Could it be the ADU board?
    Thank for any help.
  • JustManuals
    • Jan 2006
    • 9838
    Re: Konica 7155 (J32-10)
    Paul@justmanuals.com
      • 14755
      There is a black plastic guide in the turn around area with a spring on it. Either the spring has come off, or the guide is broken. The spring is at the back of the guide and so is the part that blocks the sensor.
      Hope this helps
      • Ray G.
        • Sep 2008
        • 22
        Thank for any help.
        Yes, I've had a couple of ADU boards give me that code, but more often than not it's the exit sensor at fault.
