I've looked through the copytechnet post and I am not sure which motor to order to correct this problem. The Manual shows 4 motors in the main drive assembly. (2 are the same motor). Do I order M-1 Part number A02EM10300. Is that the main motor... Thanks so much for any help !!!
Konica Bizhub C-253 Error Code C5102
Tags: None
Re: Konica Bizhub C-253 Error Code C5102
I've looked through the copytechnet post and I am not sure which motor to order to correct this problem. The Manual shows 4 motors in the main drive assembly. (2 are the same motor). Do I order M-1 Part number A02EM10300. Is that the main motor... Thanks so much for any help !!!The gene pool could use a little chlorine. -
