bizhub C250 Copy Quality Problem
  • goldencup
    • Nov 2008
    • 366
    Hi, i have a copy quality problem with one of my bizhub C250. If i print via demo page the copy is fine also via printer. But if i copy an original via top glass or feeder a black square image is blocking the copied image... (see images). Has anyone encountered this problem? This are the things i tried replacing so far just for testing purposes:
    all imaging unit
    transfer belt assy
    CCD
    still no luck.
    Any idea where this problem came from? Thank you very much.
  • jotunn
    • 618
    Re: bizhub C250 Copy Quality Problem
    It's not a problem with your machine, don't waste your time - just perform steps XII-XVII from Installation Manual, this will solve your problem.
    These are main topics:
    - XII. Adjusting Touch Panel
    - XIII. Setting Gradation Adjust
    - XIV. Date/Time Setting
    - XV. Install Date
    - XVI. Serial Number Input
    - XVII. Unit Change
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • jwrycza
        Office Systems Expert
        • Sep 2013
        • 90
        I would think it almost has to be the Glass. That is the only thing different that comes into play. Remove it and clean both sides thoroughly and see what happens.
        • Blizzoo
          • Aug 2013
          • 608
          Nothing happens...
          Follow the instructions as jotunn says
