Scanning issue
  • peppiebro
    • Jun 2025
    [Misc] Scanning issue
    Hi all,
    Have a Bizhub 501 with a scanning issue. When scan to email is used you can only scan one page. From the moment you want to scan 2 or more it stops and says that it can't make a connection. Same with scan to folder using SMB. There's also a bizhub 451 connected on the same network and that one works fine so don't think there's a network problem.
    Copying doesn't give any trouble. Printing is also fine.
    Anybody have any ideas?
    Thanks.
    Peter
  • CompyTech
    Super Tech
    • Feb 2011
    • 706
    Re: Scanning issue
    Originally posted by peppiebro
    Hi all,
    Thanks.
    Peter
    I'm not 100% on this but, I think there's a setting somewhere to set the default attachment size limit in the machine. I would snoop around in the scan settings to find it.
    • wseyller
      • Sep 2012
      • 1129
      Does it have a hard drive installed? Not sure if it would relate but I remember a different model that will allow scanning multiple pages but it creates a PDF for each page when no HDD is installed.
      Sent from my DROID BIONIC using Tapatalk
      • peppiebro
        Re: Scanning issue
        No there's no hdd. But it has always worked fine. It does create a PDF for each page when set to single page in the scanning menu.
        • wseyller
          • Sep 2012
          • 1129
          This is likely your issue:
          Using scan to SMB or E-mail, one page is fine but multiple pages will not go through. The job log indicates they were deleted due to error.
          Solution
          CAUSE: Corruption of data on the CF card.
          SOLUTION: Rewrite the Base level 10.0 Recovery firmware directly to the CF card:
          1. Remove the CF Card from the problem machine.
          2. Erase the files from the CF Card (DO NOT format the card).
          3. Download the Recovery firmware to a temporary folder on your PC and unzip it.
          4. Copy the Base firmware files to the CF card.
          5. Install the CF card in the problem machine and switch machine ON.
          6. Upgrade the firmware to Base version 20 via USB.
          If necessary, restore network settings as follows:
          1. In Admin mode → Network setting, set to OFF.
          2. Switch machine OFF/ON.
          3. In Service Mode → System 1 → Initialization, initialize Network setting data.
          4. Switch machine OFF/ON.
          5. In Admin mode → Network setting, set to ON.
          6. Switch machine OFF/ON.
          7. Enter the network settings.
          If the problem is not resolved, replace the CF card (p/n A0R7 R701 00 for bizhub 361, p/n A0R6 R701 00 for bizhub 421 and p/n A0R5 R711 00 for bizhub 501).
          • peppiebro
            Re: Scanning issue
            Solution
            Thanks. Will surely try this.
