KM 1200
  • CT Copier Repair
    • Mar 2010
    • 304
    KM 1200
    the PF703 showing a c-0263 error
    Help
    new machine for me I know is a big boy machine but I work on the big Xerox and canon boxes
    Brian
    it will load and feed a few sheets then throw the error
  • gurko_gg
    Prod.Line Technician
    • Sep 2011
    • 43
    • Mick01
      • Nov 2012
      • 362
      Re: KM 1200
      Hi,
      You have an issue with M11 shutter motor in the paper feed suction section. Try swapping the suction section with another tray and see if the fault code changes. If it does you have a faulty motor. If not i suspect either a wiring issue or the PFU driver board.
      Hope this helps.
