bizhub 601 lines on prints & copies
  • solidzdawg
    • 71
    Been taking care of 601s for awhile now but this one is a new one for me.
    601 has 1.8mil on it, everything in the scheduled maintenance is up to date (to the best of my knowledge)
    Fresh PM, New Trans/Sep unit and wires, Process section meticulously vacuumed(no sensors;P) and cleaned.
    Drum Carriage installation mode will show faint VERY faint feed direction lines of toner (kind of hard to see on pages with decent Toner Coverage), the lines are always the same and not changing
    This machine is the highest count 601 I have, so MAYBE there is something I need to do that i havent done before to keep Print Quality 100%
    Thanks for the help all you Print Ninjas, Happy New Years
    -Z
  • JR2ALTA
    • Feb 2010
    • 2033
    Did you check the fuser?
    • gurko_gg
      Prod.Line Technician
      • Sep 2011
      • 43
      • Synaux
        • Mar 2012
        • 1224
        Re: bizhub 601 lines on prints & copies
        First I would try a stop test to eliminate the fuser all together.
        Check the web roller and might want to force the corona wire cleaning.
        Is it dumping toner/developer onto the ADU?
        I recently had a 1/4" line on the top of prints and solved it be stepping up the charging grid value with no quality issues.
        • solidzdawg
          • 71
          UPDATE:
          I have ran through all suggestions and have had no luck fully resolving this issue.
          It is like ghosting on all copies and prints. Its almost like the whole page is being written an image, and its confusing me! Its like the page has toner coverage all over it, and the parts that shouldnt have any image written to it has like 2% TC and it looks like the image is running off of the page or ghosting
          Dev Unit has 500k, Drum Cartridge 500k,
          But the charging unit has never been replaced apart from the corona cleaning block and usual pm parts... and this unit is close to 2mil print count. I am hoping this will solve it, everything else has been replaced, apart from board level items(maybe the culprit is the (TCSB)
          Even running drum cartridge installation mode in Drum Peculiarity shows faint feed direction lines on the bottom of the page.
          Please help!
          • Phrag
            • Oct 2012
            • 417
            Is the black plastic ramp leading to the fuser is clean? That has little ridges on it which may be holding a little bit of residual toner.
            Just my 2 cents. I haven't had the issue you're having, so I'm taking a stab in the dark here.
            I only say this because occasionally I see that gritty black 1/4" mark on the bottom of pages, which is always dev.
            • solidzdawg
              • 71
              Fusing ramp is clean, thanks for the reply.
              Its almost like something is causing the machine to write to the whole page, when it shouldnt be like that. I will upload a pic, as I cant describe it well.
              what the hell am i missing??
              • Synaux
                • Mar 2012
                • 1224
                So the problem and evolved from lines to a ghosting issue...how did you get rid of the lines?
                What are the results of the stop test?
                Samples are always helpful.
                You might want to try flashing the firmware.
                Check the memory.
                Are you resetting the counters in present parts life and running the all adjustments in order after your PMs and other installations?
                • Phrag
                  • Oct 2012
                  • 417
                  Charge grid is seated correctly? I know I didn't seat it correctly once, and it was almost rubbing on the drum.
                  What about the LED erase lamp before the transfer unit? Does it have any hard to remove residue on it? Maybe it's faulty? uneven lighting? I'm just guessing.
                  Did you notice any error's while performing those Drum Peculiarity adjustments (ie, gamma adjust, etc) I've only ever seen Error 2 or something which was the TCS board. in the drum cartridge. Accidentally ran the vacuum over it.
                  • Synaux
                    • Mar 2012
                    • 1224
                    Looks like solidzdawg post a few minutes before me :P
                    And that TCS board is pretty expensive for a small bit of circuitry....
                    • Phrag
                      • Oct 2012
                      • 417
                      That it is, but we've got plenty of spares that work. Luckily.
                      • Synaux
                        • Mar 2012
                        • 1224
                        Sell me one!
                        • solidzdawg
                          • 71
                          Its frustrating to me.
                          Like damn is there something I am missing on the PM and now its starting to surface? Makes me paranoid lol
                          Charge grid definitely looks like its on right, this problem has persisted to 2 full PM's
                          Its a subtle pattern of ghosting, but its noticeable
                          Ive done literally 30 PMs on other machines with no problems. I dont know if this is something that is going out because it has 2 million as oppopsed to like 600k or something of that nature.
                          • Zackuth
                            • Aug 2009
                            • 448
                            Originally posted by solidzdawg
                            UPDATE:
                            The drum unit and both fuser rollers are to be replaced at 500k. It could be the drum is going out.
                            If at first you don't succeed, redefine success
                            • solidzdawg
                              • 71
                              The drum is up to date like 10k copies new..
                              I mean the actual cartridge that it goes into
