Kon/Min Biz 250 "Please Wait" message
  • onabike
    • Aug 2025
    Copier is unresponsive except a please wait message. Even if the sub switch is off the message still appears. Have swapped NVRAM, MFBS board (the one NVRAM mounts on) no change. Have also swapped Main Power supply and A board. Still no change. Contacted our friends at K/M no luck. Any hints out there. Thanks in advance.
  • beano
    • 54
    do you try reflashing it
    • DadO
      • Dec 2007
      • 404
      I had similar case last year and i fixed it whit PWB-A board, even tho that was on biz 162 but u have same message and probably same cause.
      Since u replaced the above mentioned board i suggest u try whit an cables that leads to PWB-A or try to replace whole display unit since its in close relation to PWB-A.
      Good luck.
      • fixthecopier
        ALIEN OVERLORD
        • 4713
        It sounds like a firmware issue. If you put in a new MFB, you should have flashed it. Do you have another machine close by? If so you could swap the MFB with one from a working machine.
        • mitchl
          • Apr 2007
          • 501
          This sounds NVRAMish to me either that or firmware related............. flash it and see what happens, it certainly couldnt hurt.
          • DocuSystems
            Service/IT/Integrator
            • Jan 2007
            • 54
            Scan Board..
            Try removing the scan board. If it comes up past the "Please Wait" message afterward, the Scan board needs replacement. It is on the MFBS mounted near the flash rom socket.
            If this isn't it, hard drive can cause this also, though I don't know if that option is installed.
            • onabike
              It was the op panel. Thanks for all the replies.
