Turn the main switch OFF and then ON following the instruction.
  • jimmyisec
    • 12
    Hi, i have a problem with my copier konica DI 470. when i turn it on, its giving a message on screen the message is: Turn the main switch OFF and then ON following the instruction. after a wait nothing can happen. machine is still hang on this message
  • jimmyisec
    • 12
    Re: Turn the main switch OFF and then ON following the instruction.
    [ATTACH=CONFIG]23650[/ATTACH]
    NO One know on technet forum?
    • mo0651
      • 1054
      If you are using the main switch on the left side down by your knee, then I would unplug from wall. Wait a few minutes and try again.
      • hotfuser
        • 180
        i think the problem you have got is that the copier has the wrong controller type set in tech rep.
        If you perform a memory clear this resets it too type '0'
        If it has a Pi 4700e you need to set it to o '6'
        I hope this helps.
        • jimmyisec
          • 12
          I hope this helps.
          machine is di470, not pi470
          • jimmyisec
            • 12
            I hope this helps.
            Thanks Bro. Problem Solved
            • darry1322
              • Oct 2010
              • 817
              The pi4700e is the printer interface not a reference to the copier. Glad you got it solved.
