KM Di2510f Error C05000
  • gunterf
    What should I look for with error code c05000?
  • laserman06
    Conservative in Exile
    • Dec 2007
    • 323
    Warning--Be advised that with fuser codes, some risks are involved, please seek professional help to help reduce these risks. I assume no responsibility for improper use of the the following advice.
    The C0500 code is a fuser failure to warm up(main). I have included a pdf file with what to look for.
    How to reset a C0500 code.
    Solution
    The C0500 code can be reset following the steps below:
    1. Press the soft initialization on the right side of the control panel.
    2. When the dot appears on the LCD after reboot, press the number 3 key.
    3. The mode will change to the initialization screen.
    4. Choose the selection for trouble reset.
    5. After reboot the code will be cleared.
    The family that prays together, stays together!
    Smile God created you and He doesn't make mistakes!
    Relax, God IS in control!
    Be still and know that I am God
    Ps 46:10
    • gunterf
      Thank you for the quick response, Excellent info, makes sense given that the machine worked fine one day then showed error code for fuser the next day. Where can I find information for references made in the pdf instructions?
