C253 MFP firmware
  • ck1
    • 485
    C253 MFP firmware
    Hi can we swap firmware UK version to asia version ?
  • Synaux
    • Mar 2012
    • 1224
    Re: C253 MFP firmware
    That doesn't seem like a wise thing to do...and why?
    • ni311
      • May 2008
      • 658
      Are you sure there is an 'Asia' version? I believe the firmware are the same but the languages are different, and if this is the case, I cannot see why you shouldn't swap.
      Konica Minolta Error Codes - Explanations and Solutions
      • ck1
        • 485
        Becuase my toner supply from singapore , so need convert it .
        • ck1
          • 485
          The firmware got area select and market area normaly set at euro
          • ni311
            • May 2008
            • 658
            Are you serious about that?!
            • ck1
              • 485
              Yes ,serious any issue ???
                • 14522
                Why not buy it locally. Sounds like it would be easier.
                • ck1
                  • 485
                  Hehe..... more cheaper closed the file . we dicuss regarding firmware .
                  • Synaux
                    • Mar 2012
                    • 1224
                    Why not just swap the chips?
                    Or buy some more on ebay.
                    • ck1
                      • 485
                      You are right , but waste the ori chip .....
