afr-17 pads
  • mjunkaged
    • 387
    [Misc] afr-17 pads
    Anyone have pads for the di351 2-sided doc. feeder? I'd also settle just for the part number! I don't have a parts man. for it.
    Thanks!
  • ck1
    • 485
    Re: afr-17 pads
    Can you take a photo and see. maybe i have it ...
    • Synaux
      • Mar 2012
      • 1224
      Re: afr-17 pads
      call Precision Roller
      • mjunkaged
        • 387
        Re: afr-17 pads
        Sure, it's not too much of a pain, here's a photo of one of the pads (2 needed per feeder, I'd like about 10 of them at least, 5 pair).
        Here's a pic of the entire pad assembly, but the pads are much smaller/cheaper/easier to ship. I don't really need the whole thing! Part number would be nice....thanks!
        • mjunkaged
          • 387
          Re: afr-17 pads
          Originally posted by Synaux
          They didn't have any left.
          • hotfuser
            • 180
            Re: afr-17 pads
            the part number if you require it is 4652 0752 01
            • Hansoon
              • Sep 2007
              • 3391
              Re: afr-17 pads
              or 4490-0011-01, 4490-7802-01, they are all the same.
              Remove the old pad from the black holder and replace with a piece of cleaning blade of the same size and thickness.
              Length: 26mm, width: 9.5mm, thick: 2mm
              That is working for us since two years. We are still having several rentals of this series in the field.
              Hans
              • ck1
                • 485
                Re: afr-17 pads
                [ATTACH=CONFIG]23719[/ATTACH]
                [ATTACH=CONFIG]23720[/ATTACH]
                This parts i have 6 Unit ( Ori and fully new ) , you still need it ? PM me
                • havokprod
                  • Oct 2012
                  • 159
                  Re: afr-17 pads
                  The pad material kind of looks like the one from the old 7033/7040/7045 ADF sep.
                  • mjunkaged
                    • 387
                    Re: afr-17 pads
                    I did PM you and asked how much, but your PM box is full or something. Got no reply....
