Sc 4640 in knica minlota 650
  • nasrullahbutt
    • 58
    hi every 1 plz tell me that code how i remove that cod
  • fixthecopier
    ALIEN OVERLORD
    • 4714
    The code is for a hard disk failure. You will want to check your connections and other basics but you may have to replace your hard disk. Keep in mind that heat will kill a hard drive. If the machine is in a hot enclosed place this could cause a problem. Good luck.
