Bizhub 950 c 2110 Plz help! :)
  • solidzdawg
    • 71
    [Error Code] Bizhub 950 c 2110 Plz help! :)
    Bizhub 950 pro with 2 million clicks
    Upon start up spits this code C2110. It's half way thru a PM.
    Replaced transfer wires, then assembly. Then replaced transfer guide motor..
    Starting the machine up with ADU unengaged = no code
    As soon as ADU lock Lever is engaged and doors are closed, this error appears.
    I've followed the suggested replacement list for this error, and now it's pointing to ADU board, or even power. Expansive parts left now...
    Any help or ideas would be great, I'm fairly new to working on 950s...
    -Z
  • JustManuals
    • Jan 2006
    • 9838
    Re: Bizhub 950 c 2110 Plz help!
    Paul@justmanuals.com
    • manuelcorrea
      • May 2009
      • 46
      remove registration assy. there is a gear that drives trans./sep. motor that needs to be replaced. part no. is 56ua77410. you can also try to turn it a little to where a good part of it engages the motor and it should work
      • solidzdawg
        • 71
        Thanks for prompt reply and helpful insight.
        Ordered that gear, will update tomorrow how it goes.
        Thanks a million. I owe you a beer ^_^
        • methogod
          • Dec 2008
          • 921
          i think you can turn off cleaning. I know you can on the 920s.
          Its just a dip switch setting.
          when the adu board goes its usually timing that gets goofy.
