Bizhub 36 not booting
  • ni311
    • May 2008
    • 658
    Is there any final fix for the Bizhub 36 that are not booting? The machine remains in the first screen (logo / hourglass) and after several restart it boots normally and you can enter in Service Mode. A temporary solution is to format the ssd, but at some machines, the problem reappears.
    Konica Minolta Error Codes - Explanations and Solutions
  • JustManuals
    • Jan 2006
    • 9838
    Re: Bizhub 36 not booting
    Paul@justmanuals.com
    • SmellsHot
      Head Tech
      • 512
      Check to see if you can scan to email....
      I've had two 36's already where they had boot up problems/locking up. But I've also noticed when I would go to try and send an email, the machine would say "no network setting" and error out on the screen.....even though I know the network info is set correctly
      Everyone has the right to be stupid. Some people just abuse this privelage more than others
      • ni311
        • May 2008
        • 658
        You have to input an email address (fake or not) to the administrator email, from what I remembered. The same issue is with C224e, even all the fields are filled in correctly, when trying to send an email, and error message appear: 'no sender email set' or something. Go to web interface, login as administrator and in the first tab, you'll find the field where you have to enter this address.
