bizhub c35 show insufficient HDD capacity
  • sangcom
    • Jun 2009
    • 45
    Sometimes ,We scan SMB it will show insufficient HDD capacity
    We changed new HDD, Format HDD and format SSD
    But this problem appear ''sinsufficient HDD capacity'' again
    how to fix solve this problem?
  • hdmr
    Helpdesk Engineer
    • Feb 2013
    • 51
    Re: bizhub c35 show insufficient HDD capacity
    Hi I was wondering if you got anywhere with this fault. We have a customer reporting a similair issue.
    • HoonBoy
      • May 2011
      • 130
      This is a firmware bug...
      It only happens if you scan in "compact PDF", if you change it to "PDF" you should not have this message...
      You can also downgrade the controller firmware...
      in one case we had too replace HDD
      • hdmr
        Helpdesk Engineer
        • Feb 2013
        • 51
        Hi thanks for your input. Funny thing you say its a firmware issue because the fault only arose when we completed a firmware update to resolve another issue of scanning using the doc feeder and only receiving black and white scans.
        I will update this when we have completed the call and confirm the fix. thanks again
        • HoonBoy
          • May 2011
          • 130
          Originally posted by hdmr
          Hi thanks for your input. Funny thing you say its a firmware issue because the fault only arose when we completed a firmware update to resolve another issue of scanning using the doc feeder and only receiving black and white scans.I will update this when we have completed the call and confirm the fix. thanks again
          Did you also lower the ACS level(auto color senitivity) For the black and white scans problem as well? Found under user settings -> Machine settings -> ACS Level
          • hdmr
            Helpdesk Engineer
            • Feb 2013
            • 51
            My understanding is that this works fine in Black and White. I'm working from a helpdesk so haven't tested this out myself fully, going on what the customer is feeding me. Which we all know could be something completely different.
            • hdmr
              Helpdesk Engineer
              • Feb 2013
              • 51
              Our Hardware Engineer, reinstalled the same firmware with not effect on fault. so backdated the firmware which resolved the issue as suggested by HoonBoy.
              Thanks for all your assistance.
              • giddyupngo
                • Oct 2014
                • 109
                How do you set the scan settings to "PDF" rather than "Compact PDF" as default?
                Hi,
                I'm also dealing with the insufficient HDD problem on C35. Konica Minolta is recommending to set the scan file type to "PDF" rather than "compact PDF" as a default. Does anyone know how to do this? You can change it at the operation panel, but anytime someone hits the "reset" button it reverts back to "compact PDF". The closest I've come to it is changing a program in the PageScope Web connection through the browser. Does anyone have detailed instructions. Thanks in advance.
                • allan
                  RTFM!!
                  • 5459
                  Goto scan settings and change compact PDF to PDF. then
                  Goto utility->user settings->scan settings->default scan settings->current settings.
                  I only get this problem on the B36/42 machines. Them firmware fix does work.
                  But its not base level firmware its special firmware.
                  Whatever
                  • giddyupngo
                    • Oct 2014
                    • 109
                    Thanks Allan! I saw the default button before, but it was greyed out, did not think it would only be available when the file type had changed from the default. THANKS!
