THICK 4 jam IN C550
  • karim-tech
    • 47
    [Jamming] THICK 4 jam IN C550
    hello,
    please help,
    whene i chose to select thick 4 on bypass it's done but it can't print on all what i get is a jam on the midle of paper, but whene i select thick 3 it's ok even when i print on a 300G.
    i had change the NVRAM but the problem steel remain .
    thank you
  • Synaux
    • Mar 2012
    • 1224
    Re: THICK 4 jam IN C550
    Originally posted by karim-tech
    hello,
    please help,
    thank you
    I would say clean/replace rollers, but if its working with Thick3 then it might not help.
    Either way, its working with Thick 3 so what is the problem exactly?
    If this is happening on 11x17 1/3 down the sheet there is a possibility that you need to replace the PCRB board.
    Also TAUS0900864EN discusses how to improve the feeding of thick paper, let me know if you need the documentation.
    I hope you didn't change the NVRAM due to this [non?]issue
    • karim-tech
      • 47
      thx i have the service field but doesn't help,
      i had the problem with all sheet whene i select thick 4
      it's not a mechanic problem
      yeah i had change the NVRAM to solve the problem but just for nothing it steel on
      thx 4 all
      • Synaux
        • Mar 2012
        • 1224
        thx 4 all
        Did you go through Konica to replace the NVRAM or simply use one from another machine?
        The documentation that I am referring to is not in the Service Manual..
        ...Have you attempted the following modifications: 6910.pdf
        • Synaux
          • Mar 2012
          • 1224
          ...also is this happening when printing and/or copying; can you get it to feed in Service Mode > Test Mode > Running Mode?
