Error code c3102 on c451
  • kamoga
    • Jun 2013
    • 36
    Dear all
    i have i printer bizhub C451
    and it has an error code c-3102
    i tried to swap the fusing motor with the one
    whichich is the same in the same machine but it
    failed , i tried to change the fusing unit but also it failed
    some help pliz
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    Re: Error code c3102 on c451
    replace the black plastic rotation sensing housing and the 2 photo sensors at the rear right side behind the fusing unit.
    • Synaux
      • Mar 2012
      • 1224
      Are you clearing the code before you do all this work with trouble reset?
      Ensure that the fuser is seating properly and the gears are in good working order and the lock lever is good.
      Did you replace the fuser motor with a c451-c650 series or c452-c652 series model?
