C284 /224
  • CrapAimer
    • 296
    C284 /224
    Trying to upgrade the firmware, when looking at the diagram it says take out the screw lift up the plate and insert the usb stick into the slot beside the cable, but when you lift the plate the slot is above it, is the cable in the wrong position ? machine straight out a box and working. any feedback would be welcome. Been trying the tech website bloody hopeless
    Regards
    George
  • emujo
    • Jun 2009
    • 3009
    Re: C284 /224
    The slot that is uncovered when you lift the plate is the only slot that can take a firmware update. If there is anything in this port, remove it and plug it into any open slot (other that one designated as FAX 1 or 2). EMujo
    • MDR24
      • Apr 2013
      • 64
      Re: C284 /224
      Is it definetly a C224/224 and not a C224e/284e?...im pretty sure on the E series the slot is above the cable and on the original 224/284 the slot is beside?
      • CrapAimer
        • 296
        Re: C284 /224
        thanks all I got it sorted
        George
        • JustManuals
          • Jan 2006
          • 9838
          Re: C284 /224
          George
          George - Tell us what you did to solve it so that someone in the future with the same problem might be able to use it to help him/herself.
