I have a 6500 that has the firey rip and i would like some adjustability with the colors some times like every digital blues are turning purple. what would you suggest
Bizhub 6500 color adjusting
Re: Bizhub 6500 color adjusting
Paul@justmanuals.com
Start with calibration, both scanner and printer.
Then make sure your colour workflow (input/output profiles, GCR settings, Spot) matches the files you are printing.
Importing complete pdf files via Command Workstation will likely produce different (often correct) results.Comment
Already chasing. The bad part is the more I let the tech do the worse it is getting. That is why I posted.Comment
AAH the wonderful world of colour management. It can be a very simple or extremely difficult and frustrating process.
Firstly there has to be a uniform and consistent colour workflow from start to finish.
If you are working with a PDF workflow disable colour management through the advanced tab of the print dialog box within Acrobat. If this is not done then you will have two levels of colour management (one through the app and the other through the RIP) which is a bad idea.
Correct (and frequent) Calibration must be performed. What i mean by this is as follows:
Calibrate on the stock you are going to be printing on.
When calibrating select the correct profile (coated vs uncoated). If this is not correct the RIP will not set the colours correctly
Select the screen that you will be printing with (dot,line). If you are calibrating to dot screen then printing to line screen you are wasting your time calibrating.
The most critical part of calibration is ensuring you have sufficient "Dmax" levels. When you calibrate look at the "actual" vs "target" graph. If you are not acheiving sufficient Dmax levels then you will not be able to match high coverage prints (100%). If you are not achieving this your engine needs attention (worn devs, drums, Tbelt unit etc)
In regards to Frequency (how often to calibrate) I suggest the following.
Every morning (it is recommended to run a small amount of prints prior to "warm up" the engine)
Before printing a proof
Before printing an important colour critical file
If a colour shift is noticed during a colour critical job.
Finally ensure you are printing using the output profile that you are applying the calibration to. Again you are wasting time calibrating if this is not done.
I hope this helps you in achieving more consistent results with your machine.Comment
Mick01: I'm still learning all this but wow nice info. I wish they covered this in my Fiery Color controller classroom instead of just teaching us unrelated crap like how to scan to smb which I all ready knew.
Sent from my Nexus 7 using TapatalkComment
