sc 50-02 on bh 920
  • marlon29
    • May 2011
    • 51
    sc 50-02 on bh 920
    hi guys,
    anyone encountered the code sc 50-02 on bizhub 920?
    We have replaced already the PRCB but it did not correct the problem...
    Upon start up, the machine will have an error code without any part/s initializing....
    Thanks in advance
    Marlon
  • JustManuals
    • Jan 2006
    • 9838
    Re: sc 50-02 on bh 920
    Paul@justmanuals.com
    • methogod
      • Dec 2008
      • 921
      Error code SC50-02 (bizhub PRO 920) or C-0002 (bizhub PRO 950).
      CAUSE: Main body drive serial input abnormality 2 due to failed ADU Driver Board assembly (ADUDB). ICP5 is OPEN (bizhub PRO 920) or ICP17 is OPEN (bizhub PRO 950). Both are for HV2.
      SOLUTION: Replace the bizhub PRO 920 ADUDB (p/n 57GA -907 2E) or the bizhub PRO 950 ADUDB (p/n A0Y5 H070 02).
      CHECK ICP5 SEE IF ITS OPEN...
      I would escalate after that as it does say something about these errors being security related. Not sure what they mean but maybe its worth calling
