Konica Minolta C-203 service code BOO3
  • Buddy with ACR
    • Sep 2011
    • 13
    Does any one know what this could be? I perform trouble reset but it keeps coming back. Had to replace the MFP board but would like to repair it if possible.
  • hotfuser
    • 180
    Re: Konica Minolta C-203 service code BOO3
    If you disable the fax option with in service mode this should hopefully get rid of the code. if it has a fax unit fitted re-seat the option board and make sure the FK-502 is connected fully.
    i hope this helps
      • 14755
      Sounds like someone removed the fax board and didn't turn it off in service mode. System 2- option board status.
      • JustManuals
        • Jan 2006
        • 9838
        http://www.justmanuals.com
        Paul@justmanuals.com
