bizhub c351 locked up
  • brent
    • Nov 2008
    • 1214
    I have a high metered c 351 that works only as a copier. I went and put in it today a drum unit. and it accepted it. It was also asking for a transfer roller and another item but I can not access the utility on it. cant get into admin settings. no printing. no counters etc
    I had this happen about a year ago and they didnt' wanna fix it. just curious if anyone elses has had this happen before. is it just a display pannel that is bad? or is it more internal things. I appreciate any help on this
    brent
  • habik
    • 2013
    Re: bizhub c351 locked up
    brent
    Trouble Reset first!
    Clear the Transfer roller in Service Mode later.
    Firmwares HERE
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • brent
        • Nov 2008
        • 1214
        I never thought of trouble reset. I am looking too much into this
        and paul. is this just what you do is post? do you do this to everybody?
        because I do not require manuals. if you are advertising Iguess that is ok
        but every time you post I guess I just tell you I don't need a manual
        I do appreciate this site. and try to donate to it by way of financial means
        every month...
        I will check into it habbik
        brent
