Hi! I have a problem in KM 920, it jam in every cassette and bypass. Try to replace the vertical conveyance clutch and registration still the paper is stuck in pre transfer roller it didn't reach transfer unit. try to clean also the sensors in ADU fusing and exit. Misfeed code is J32-01. One thing i notice that the centering sensor is not lighting. I event try to interchange the sensor PS-44 and PS-54 to bypass sensor and no luck. Any thought regarding this issue is highly appreciated.
Konica Minolta 920
Re: Konica Minolta 920
Hi! yes the code is J31-02 but it will not reach even in the transfer unit. Thats why i also clean the sensors in fusing ,exit and even in duplex. very rare that one paper will pass but the next will jam with the same location.Comment
Hi. what part exactly was the cause of the failure? I have the same in 920 pro.Comment
I want to make sure before buying this part. In my machine the paper leaves the fusing but not entered the paper exit unit. One detail - Face down - stays in fusing and additionally information (Lower level M4 and pull out ADU unit) Face Up - comes out halfway with fusing from the machine without errors (only J32-01)Comment
I am a user with a very long experience. Info- J31-02. Lower level M4 and pull aut ADF unit. (when Feed down)Comment
