bizhub 601 2nd side missing print on copy
  • brent
    • Nov 2008
    • 1208
    if I didn't see it I wouldn't believe it. its a bizhub 601 first side ok this is a double sided 11 by 17 and when the copies are in the output tray. it is on the underside. I measured it and am submitting a copy for a sample here. it is a quarter there. I measured the area it is 5 and 1/2 by 8 1/2
    here is the kicker. it wont do it today. it does it spuratically.. anyone have any thoughts what it might be?
    brentmissing copy.pdf
  • SmellsHot
    Head Tech
    • 512
    Re: bizhub 601 2nd side missing print on copy
    Will this happen on multiple copies? Trying to eliminate scanner section.....
    Is this a 4in1? Or is your sample suppose to be the entire page??
    I've had similar issues with a bad ICB....blank pages & 1/2 pages.....
    Everyone has the right to be stupid. Some people just abuse this privelage more than others
    • brent
      • Nov 2008
      • 1208
      It it does it on regular paper or 11 by17. That sample was a full 11 by 17 with a full pic
      typically it seems to be intermittent. But it happens on multiple copies
      • WildbillC
        • Oct 2010
        • 49
        This is a copy job not a print job, correct?
        • brent
          • Nov 2008
          • 1208
          Yes it is a copy job. 1 to 2 on the glass. I have not hooked it up as a printer as of yet
          thanks for the help
          Brent
