I need to replace my Transfer Belt Unit on my KM Bizhub C351. Apparently, it is suppose to be easy to do, I just can't figure it out. Does anyone know how and can give me instructions?
Replace Transfer Belt Unit on Bizhub C351
open right hand side door and remove 1 screw from a silver bracket front end of the machine and 1 from a silver bracket from the rear side of the machine, the brackets should pop out about 10cm.
Then open the left side door and remove the collection bottle, then pull out the transfer belt, if it does not want to come just check that the silver brackets on the right side of the copier have 'popped' out all the way. Should take you no longer than 30 sec'sThe gene pool could use a little chlorine. -
open the door on the left side (the one that the finisher was blocking)
take out the Waste Toner Box
Now you can get to the belt, i think theres 2 screws you need to take off and you can slide it out.
once you put the new one in you have to config/adjust it in the tech menu so the colours and alignment are rightComment
U R THE MAN!!!! I appreciate your help, it took me about 30 seconds to figure out. Now its talkin about a malfunction detected, call you tech rep. The unit is in correctly and everything is back the way it was, dont know what its talkin about. Its saying C-2152
Any clue to what that is?Comment
The gene pool could use a little chlorine.Comment
If you use a pico fuse you can do it without removing the unit. Take off the small cover to the left of the yellow toner and cross the two wires with the fuse. Works great. And saves time.Comment
redime
Transfer belt will typically go 2-3 times expected life so long as it is well cared for. Make sure the belt cleaner on the end you pull the belt out from is kept clean (if you are standing facing the belt as it were coming out of the machine) there are two screws on the right hand side that hold a black plastic piece on the cleaner that will pop the cleaner off.
Vac if out and make sure it looks all pretty inside, wipe your belt off with some iso. alcohol and reasemble. Its a little tricky, theres a white gear that sits on a metal D post on that black plastic piece of took off -- but a non tech. should be able to figure it out with 15-20 mins. of fooling around. Its simple once you get the hang of it.
pop a new fuse in and be on your way
Same with the fuser units, they will code between 250-300k clicks, but you can reset and double the life.Comment
ingridmv
C450
I hate to sound dumb, but were can I buy the fuse? is it the same procedure with a Bizhub C450? thanks for your help!Comment
ingridmv
ozzyozzie
Re: Replace Transfer Belt Unit on Bizhub C351
Then open the left side door and remove the collection bottle, then pull out the transfer belt, if it does not want to come just check that the silver brackets on the right side of the copier have 'popped' out all the way. Should take you no longer than 30 sec'sComment
