KonicaMinolta bizhub 1050???????
  • pierre
    • Mar 2008
    • 12
    Hi everybody,
    One of our important customer wanna buy high volume machine. He print about 20k print daily.
    I suggest him to get bizhub 1050
    Dose this machine have alot of problems ????
    please tell me the magor problems of this machine.
    thanks.
  • the pipster
    I have operated a 1050 for about a year now. It is a truly great workhorse machine. Although I'm only running 3/4 of the volume of your customer, I'm sure it could handle it. The only comparable machine in this volume range is a Xerox Docutech type but the price on that is much higher and I'm not sure its worth it.
    • pierre
      • Mar 2008
      • 12
      Thanks all
      • random
        We have a customer who has done 7 million in just over 2 years this machine is unstoppable.
        • pierre
          • Mar 2008
          • 12
          Thanks all for passing by
          • ni311
            • May 2008
            • 658
            Great machine but with one condition: you have to work it hard. It the machine is working, you won't get any major problems, if it stays too long you'll end up with some nasty problems... Also, replace with only OEM parts and consumables.
            Highly recommended for high volumes.
            Konica Minolta Error Codes - Explanations and Solutions
            • skinnyb
              • Jul 2008
              • 291
              3 in one building with around 8M each after 18 months. They run great if you run them. Saddle finishers require some finesse if they use them alot. Lots of cables to slip off track and break. The PM cycle is 750K but we are getting upwards of 2 million with only a mid cycle cleaning web change...
