FIERY IC412 BHC 220
  • monkees
    • Jan 2011
    • 40
    FIERY IC412 BHC 220
    Hello to all
    I have this weird problem of fiery IC 412 windows 7
    E10-44B6 server
    EFI Fiery System 8e Release 2
    vs 1.1
    two KONICAMINOLTA BHC 220
    Sending a print A3 COLOR the BHC 220 receives the data and the fiery cancels the job
    only in A3 color (not on all computers)
    Color images are printed regularly in A3
    ACTION IN THE FIELD:
    Fiery factory reset
    Uploaded pacth 1dzdzl, 1a24ed
    trial with crossover cable txt file A3 COLOR the fiery cancel printing
    PS print A4 color all ok
    help me
  • habik
    • 2013
    Can you post fiery setup report? Whats yourPS SETUP
    Sent from my iDon't believe in marketing device using Tapatalk
    Firmwares HERE
    • Dayer
      • Oct 2013
      • 11
      Re: FIERY IC412 BHC 220
      Could be that your fiery is set up to cancel jobs with errors in it ie. wrong media type sent. I would check in the fiery settings, you can tell it to come up with a error message instead or to force print.
      • TheOwl
        • Nov 2008
        • 1732
        Print out a Job Log from the Fiery once you have sent a job that errors. The Job Log must come from the Fiery and not the machine.
        This should tell you why the job is being cancelled and I believe that Dayer might be spot on with the Media Type or Size being why the jobs are cancelled.
        • EarthKmTech
          Step aside, noob
          • May 2009
          • 2139
          I was told way back in the day when these machines first came out you were not allowed to install fiery's on C220's - it was only an option on C280 / C360, I always assumed it was just a marketing decision since the machines run the same firmware anyway, but the C220 does have a different mfp board.
          Has it ever worked or is this a new setup ?
          • monkees
            • Jan 2011
            • 40
            Italian configuration otherwise I have to go back to the customer to print it in English
            thank you
            • Mr Spock
              Vulcan Inventor of Death
              • Aug 2006
              • 2064
              According to the cross reference this is what the IC-412 goes to.
              IC-412
              Image Controller (EFI)
              A127WY2\
              bizhub C280
              bizhub C360
              bizhub C452
              bizhub C552
              bizhub C552DS
              bizhub C652
              bizhub C652DS
              • occus
                • 337
                yes, Fiery is from c280 upward... same in the actual bizhub series
                • monkees
                  • Jan 2011
                  • 40
                  Re: FIERY IC412 BHC 280
                  sorry I was wrong model BHC 280
                  from this customer I follow bhc .360 .451 .452 220.280
                  the fiery is installed on 2 bhc 280
                  • TheOwl
                    • Nov 2008
                    • 1732
                    As I can't understand Italian, here is something else that might help you find out what is going on.
                    Could you please install CommandWorkstation on the computer that you are having issues with and have that running. Print off a job that you know will cause the fault and watch what the job does in CommandWorkstation.
