CF3102 Banding
  • Brent Warwick
    • Jun 2025
    CF3102 Banding
    Hi there,
    Well, I'm one step closer to being out of the woods with our new printer. I've cleaned the LED print heads, erase heads, and electrostatic charger wires (which helped a lot on other prints) but now when I print a black test sheet I get this:
    Something else to clean? Any ideas are very appreciated.
    -Brent
  • ck1
    • 485
    Re: CF3102 Banding
    Did you check the Developer unit ?
    • Brent Warwick
      Re: CF3102 Banding
      You mean the ATDC Toner Supply check? If that's what you mean then no. I'm pretty good with tech but a novice in copiers so if you can be more specific it would definitely help.
      -Brent
      • ck1
        • 485
        Re: CF3102 Banding
        -Brent
        No the dev tank ,maybe dirty .
        • Brent Warwick
          Re: CF3102 Banding
          If the printer has a developer tank I'm stumped as to where it is. The only reference I can find to developer (again, I'm no expert) is the service manual referring to the ATDC Toner Supply where it talks about performing a "developer agitation".
          -Brent
          • ck1
            • 485
            Re: CF3102 Banding
            Look this photo
            Discover the magic of the internet at Imgur, a community powered entertainment destination. Lift your spirits with funny jokes, trending memes, entertaining gifs, inspiring stories, viral videos, and so much more from users.
              • 14563
              Re: CF3102 Banding
              To me it looks like either a dirty or failing printhead, or foreign material in the dev unit.
              Hope this helps.
              • Brent Warwick
                Re: CF3102 Banding
                Well, if I make test prints with any of the three other colors they turn out ok so I'm going with a dirty or failing imaging unit. If I print a lattice in black the print looks great--it only seems to be a problem with a lot of coverage. There's plenty of toner and I've taken the imaging unit out and shifted it side to side to distribute the toner and the print results were the same. I'm not sure at this point if there's anything else to check without getting a technician to take a look.
                Thanks to all for the help.
                -Brent
