FWselect
  • Phrag
    • Oct 2012
    • 417
    FWselect
    Hate to ask something of you guys again, but it's bugging the hell out of me.
    I remember hearing/seeing something about FWselect (before the 4 series machines came out)
    I thought I had something on my laptop about it, but alas, I do not. I tried searching the google for it (and got a 500 error on the only result I found that would give me the info), as well as CSES, which only gave me actual firmware.
    I have a couple of questions;
    1. Is it as simple as adding a folder to my USB Root named "FWselect" and then placing the firmware files in that (without folders). I get the feeling it is.
    2. Does this work with the new 4 and e series machines as well?
    Once again, I hate to be a pain, but even a link to some resources that you found helpful would be greatly appreciated.
    Cheers.
  • Phrag
    • Oct 2012
    • 417
    Re: FWselect
    Everybody stop looking! I found it.
    "The procedure to store FW into USB memory
    (1) Place a set of FW for a model on the root directory of a USB memory
    (3) Place folder(s) for other FW(s).
    Note: The name of folder must be within 40 alpha-numeric charactors"
    If this is correct, can anyone confirm whether this still works with the 4/e series machines?
    • emujo
      • Jun 2009
      • 3009
      Re: FWselect
      Yes.
      • Phrag
        • Oct 2012
        • 417
        Re: FWselect
        Cheers emujo.
        • pajeroid
          • Jul 2009
          • 130
          Re: FWselect
          Digging up an old post here, but does anyone know if it is possible to add firmware for different models onto one USB stick. Would be great to give an engineer a stick with all the range on it.
          • lilleputte
            • Jan 2013
            • 153
            Re: FWselect
            Yes this is possible ,
            • pajeroid
              • Jul 2009
              • 130
              Re: FWselect
              Great, how would I put C284 and C284e on the same stick then, as an example?
              • Naahoj
                • Nov 2016
                • 9
                Re: FWselect
                yes i think this is possible, because the file names should be different.
                so the machine will find the right one by it self.
                Best regards
                Naahoj
                • pajeroid
                  • Jul 2009
                  • 130
                  Re: FWselect
                  Well to save everyone else wasting their time.. No, it's not possible. It asks you if you want to overwrite a bunch of files when you try and put C224 firmware on a C224e USB.
                  • emujo
                    • Jun 2009
                    • 3009
                    Re: FWselect
                    It most certainly IS possible, we do this all the time to keep from having to keep track of multiple USB drives, I have one that holds 5 different firmware files, and 1 that holds 8 or 9 movie files. You must add the folder structure exactly as posted above. Emujo
                    • pajeroid
                      • Jul 2009
                      • 130
                      Re: FWselect
                      Right - well the instructions say you must have firmware in the root of the stick as well as the FWSelect folder - so surely you must put the firmware of the correct model in root?
                      Are you telling me I could put a C284e firmware in the root of the stick, and then the C284 (not e) in the FWSelect folder and the machine will boot and I will be able to select the C284 firmware by using Firmware Select?
                      • emujo
                        • Jun 2009
                        • 3009
                        Re: FWselect
                        That is correct, you will have the C284e firmware (or any other e series) loaded on the USB drive. You will add a "FWSelect"(case sensitive) folder and in that folder you will have a subfolder called "C284" or something of your choosing. The C284 firmware will be extracted in this folder. When you power up the device in firmware up mode you will press the FW select ICON then the pick the folder containing the firmware for this device. The firmware on the root just allows for the device to come up in firmware load mode. If you press start from here then of course you will get a wrong firmware message. Emujo
                        • pajeroid
                          • Jul 2009
                          • 130
                          Re: FWselect
                          Thanks for taking the time to answer and hope you can help me get this working as I've tried:
                          • Putting C284e in the root - Putting C284 in FWSelect (Case correct)
                          • Putting C284e & C284 in the root (skipping some of the duplicated files from the C284) and then C284 in the FWSelect folder
                          I know the firmware is good, as I put the C284 in the root and it updated the machine no issues. What am I missing?
                          • emujo
                            • Jun 2009
                            • 3009
                            Re: FWselect
                            Put any firmware on the root, put a FWSelect folder on the root, in FWSelect, put a folder called C284, in this folder put the c284 firmware files. You can put multiple folders in FWSelect for many nachines, just be sure to name the correctly so you don't try to put the incorrect firmware into a device. Emujo
                            • pajeroid
                              • Jul 2009
                              • 130
                              Re: FWselect
                              That's what I've done - but it just does this, with a different model in root. This is with a FWSelect folder on the root with my C284 firmware in. The firmware in the root is a C284e. Does it only work with the older firmware in root and the C284e in the FWSelect folder?
                              Honestly, I've tried every combination!
