Konica Minolta C353
  • junidexy
    • Sep 2013
    • 32
    Konica Minolta C353
    I have Konica Minolta C353 Copier, last one week I have Black print Problem, when I test the Demo Page , the Black place not print also I check the Back Unit Gradation, I change another Black Drum unit , but problem is same
    I attached the both Demo Page and the gradation page also, any one can help me to solve this issue
  • Phrag
    • Oct 2012
    • 417
    Re: Konica Minolta C353
    Have you tried a stop-test to see where it's appearing? It could be the transfer belt, if you've already changed the black drum. Or possibly even a dirty fuser?
    • minimerlin
      • 851
      Is this the same post as the thread from Balendran? The gradation pattern is the same one!!
      Please do not PM me without asking first.
      • Synaux
        • Mar 2012
        • 1224
        I was just about to jump on that!
        People begging for help with no patience or tact are annoying.
        • JustManuals
          • Jan 2006
          • 9838
          Paul@justmanuals.com
          • junidexy
            • Sep 2013
            • 32
            Dear Sir, I change the Fuser Unit set , but the Image is same , no change in the Print, I attached the Demo Print Here again after change the Fuser Unit
            • Hansoon
              • Sep 2007
              • 3391
              Guy you need a tech knowing this type of equipment and having the necessary experience and manuals.
              What you are doing is almost as useful as Voodoo....
              Hans
              • ck1
                • 485
                you mean the black line on side or the dots ? you copy or print the sample ?
                • AjitN
                  • Mar 2009
                  • 287
                  Try Initialize+Stabilize in service mode. If it fails to improve the quality, I think it could be PH or PRCB. Black reproduction is poor below 90%.
                  All the best.
                  • balendran
                    • Feb 2014
                    • 9
                    this konica minolta 253 . i have attached a gradtion of black. in that gradtion first two lines are very dark but other lines are very light
                    i have changed the HV board , Drum unit , and the laser unit but no improvement in the black gradtion please help me in this problem.
                    i have attached the black gradtion page below
                    • RRodgers
                      • Jun 2009
                      • 1947
                      Have you ran the gradation adjustments?
                      • minimerlin
                        • 851
                        I am confused.....who actually has the problem? There are two posters on this thread asking for help but it sems to be the same fault!? Or have I flipped at last?
                        I agree that the grad adjust should be done!
